8 channel BT878 3V and 5V notch
ceskobassman
Post by ceskobassman » Fri Mar 18, 2011 12:07 am
I've got a pc that I would like to use with zoneminder.
Unfortunately it doesn't have 32bit PCIs but only 64bit pci-x at 100 and 133MHz.
I would like to know if the 8 channel BT878 PCI card sold by camsecure will fit in it:
camsecure DOT co DOT uk SLASH CamsecureBT878aPCICard DOT html
They say that I should have a 5V PCI, but as far as I know all new PCI slots runs at 3V.
Any suggestion?
Thanks, Francesco
PS: I'm sorry but as a new user I can't insert links
whatboy
Re: 8 channel BT878 3V and 5V notch
Post by whatboy » Fri Mar 18, 2011 4:02 am
Type the link then Select the whole link and Click on the URL button, or put it like this ink where link is like http://www.example.com or just type it!!!
ceskobassman
Post by ceskobassman » Fri Mar 18, 2011 8:40 am
As I wrote in the PS as a new user I can't insert outgoing links...
Users browsing this forum: No registered users and 16 guests
