airlive ip cameras
jorgus
airlive ip cameras
Post by jorgus »
Hi
I read your post about airlive od-600hd http://www.zoneminder.com/forums/viewto ... a81d2a8c57, I have configure same as the readme.txt from bc-ipptz.zip but dont work, in options, Images tap, the STREAM_METHOD must be mpeg or jpeg? I have also cctv cameras and dont work when STREAM_METHOD is mpeg.
With the airlive ip cameras type POE-100cam vs2 and WL-1000cam, which is the correct configuration for
Add Airlive camera as a monitor in Zoneminder:
Source Type: Remote
Remote Protocol: HTTP
Remote Method: Simple
Remote Host Name: admin:airlive@192.168.1.101 (substitute for own login:password@ip)
Remote Host Port: 80
Remote Host Path:/mjpg/video.mjpg?resolution=vga
Specially for Remote Host Path
sorry for my poor poor english
jorgus
Post by jorgus »
Hi
I tried many paths I tried to figure it out with WireShark and found "jpg/image.jpg"
I tried of the following form
With WL-1000cam work good this config.
     Remote Host Name: admin:airlive@192.168.1.250
     Remote Host Path: /jpg/image.jpg
but only with this resolution 320x240.
but with POE-100CAMv2 and POE-200CAMv2 don't work the same configuration, I try with the browser access to http://IP100cam/jpg/image.jpg and http://IP200cam/jpg/image.jpg but in Remote Host Path in the zoneminder configuration dont work.
have you any idea what is wronk?
thanks
kingofkya
Post by kingofkya »
Did you set shared mem.
Also find and show us some of zm's logs.
Try:
/var/log
/tmp
jorgus
Post by jorgus »
I was looking in /var/log/zoneminder/zmwatch.log and found this:
09/04/10 08:31:35.354487 zmwatch[12980].ERR [Can't get shared memory id '7a6d0008', 8: No existe el fichero o el directorio]
09/04/10 08:31:35.355160 zmwatch[12980].ERR [Can't get shared memory id '7a6d0007', 7: No existe el fichero o el directorio]
09/04/10 08:31:35.355460 zmwatch[12980].ERR [Can't get shared memory id '7a6d0009', 9: No existe el fichero o el directorio]
09/04/10 08:31:45.357621 zmwatch[12980].ERR [Can't get shared memory id '7a6d0008', 8: No existe el fichero o el directorio]
09/04/10 08:31:45.358225 zmwatch[12980].ERR [Can't get shared memory id '7a6d0007', 7: No existe el fichero o el directorio]
09/04/10 08:31:45.358493 zmwatch[12980].ERR [Can't get shared memory id '7a6d0009', 9: No existe el fichero o el directorio]
09/04/10 08:31:55.360602 zmwatch[12980].ERR [Can't get shared memory id '7a6d0008', 8: No existe el fichero o el directorio]
09/04/10 08:31:55.361159 zmwatch[12980].ERR [Can't get shared memory id '7a6d0007', 7: No existe el fichero o el directorio]
09/04/10 08:31:55.361392 zmwatch[12980].ERR [Can't get shared memory id '7a6d0009', 9: No existe el fichero o el directorio]
09/04/10 08:32:05.363514 zmwatch[12980].ERR [Can't get shared memory id '7a6d0008', 8: No existe el fichero o el directorio]
09/04/10 08:32:05.364079 zmwatch[12980].ERR [Can't get shared memory id '7a6d0007', 7: No existe el fichero o el directorio]
09/04/10 08:32:05.364315 zmwatch[12980].ERR [Can't get shared memory id '7a6d0009', 9: No existe el fichero o el directorio]
09/04/10 08:32:15.366471 zmwatch[12980].ERR [Can't get shared memory id '7a6d0008', 8: No existe el fichero o el directorio]
09/04/10 08:32:15.367121 zmwatch[12980].ERR [Can't get shared memory id '7a6d0007', 7: No existe el fichero o el directorio]
09/04/10 08:32:15.367579 zmwatch[12980].ERR [Can't get shared memory id '7a6d0009', 9: No existe el fichero o el directorio]
09/04/10 08:32:25.369867 zmwatch[12980].ERR [Can't get shared memory id '7a6d0008', 8: No existe el fichero o el directorio]
09/04/10 08:32:25.370425 zmwatch[12980].ERR [Can't get shared memory id '7a6d0007', 7: No existe el fichero o el directorio]
09/04/10 08:32:25.370669 zmwatch[12980].ERR [Can't get shared memory id '7a6d0009', 9: No existe el fichero o el directorio]
09/04/10 08:32:35.372746 zmwatch[12980].ERR [Can't get shared memory id '7a6d0008', 8: No existe el fichero o el directorio]
and in /var/log/zoneminder/zmdc.log
09/04/10 08:32:35.089900 zmdc[12907].INF [Starting pending process, zmc -m 7]
09/04/10 08:32:35.091038 zmdc[12907].INF ['zmc -m 7' starting at 10/04/09 08:32:35, pid = 13665]
09/04/10 08:32:35.357538 zmdc[12907].ERR ['zmc -m 7' exited abnormally, exit status 255]
09/04/10 08:41:17.066021 zmdc[12907].INF [Starting pending process, zmc -m 8]
09/04/10 08:41:17.067186 zmdc[12907].INF ['zmc -m 8' starting at 10/04/09 08:41:17, pid = 13737]
09/04/10 08:41:17.208792 zmdc[12907].ERR ['zmc -m 8' exited abnormally, exit status 255]
09/04/10 08:41:18.010816 zmdc[12907].INF [Starting pending process, zmc -m 9]
09/04/10 08:41:18.012122 zmdc[12907].INF ['zmc -m 9' starting at 10/04/09 08:41:18, pid = 13739]
09/04/10 08:41:18.214296 zmdc[12907].ERR ['zmc -m 9' exited abnormally, exit status 255]
what it means?
kingofkya
Post by kingofkya »
IT means you need to set shared memory its in the Documentation and the forum. (Most common problem)
jorgus
Post by jorgus »
I add to
[root@camaras ~]# vim /etc/sysctl.conf
kernel.shmall = 256000000
kernel.shmmax = 256000000
But still it generates the same error log
[root@camaras ~]# vim /var/log/zoneminder/zmwatch.log
10/04/10 18:04:37.413684 zmwatch[3839].ERR [Can't get shared memory id '7a6d0007', 7: No existe el fichero o el directorio]
10/04/10 18:04:37.413985 zmwatch[3839].ERR [Can't get shared memory id '7a6d0009', 9: No existe el fichero o el directorio]
10/04/10 18:04:47.416150 zmwatch[3839].ERR [Can't get shared memory id '7a6d0008', 8: No existe el fichero o el directorio]
10/04/10 18:04:47.416724 zmwatch[3839].ERR [Can't get shared memory id '7a6d0007', 7: No existe el fichero o el directorio]
10/04/10 18:04:47.416963 zmwatch[3839].ERR [Can't get shared memory id '7a6d0009', 9: No existe el fichero o el directorio]
10/04/10 18:04:57.419092 zmwatch[3839].ERR [Can't get shared memory id '7a6d0008', 8: No existe el fichero o el directorio]
10/04/10 18:04:57.419661 zmwatch[3839].ERR [Can't get shared memory id '7a6d0007', 7: No existe el fichero o el directorio]
10/04/10 18:04:57.419900 zmwatch[3839].ERR [Can't get shared memory id '7a6d0009', 9: No existe el fichero o el directorio]
10/04/10 18:05:07.422037 zmwatch[3839].ERR [Can't get shared memory id '7a6d0008', 8: No existe el fichero o el directorio]
10/04/10 18:05:07.422606 zmwatch[3839].ERR [Can't get shared memory id '7a6d0007', 7: No existe el fichero o el directorio]
10/04/10 18:05:07.422845 zmwatch[3839].ERR [Can't get shared memory id '7a6d0009', 9: No existe el fichero o el directorio]
[root@camaras ~]# vim /var/log/zoneminder/zmdc.log
10/04/10 17:45:30.047401 zmdc[3763].INF ['zmc -m 8' starting at 10/04/10 17:45:30, pid = 3853]
10/04/10 17:45:30.156852 zmdc[3763].ERR ['zmc -m 8' exited abnormally, exit status 255]
10/04/10 17:45:31.059151 zmdc[3763].INF [Starting pending process, zmc -m 9]
10/04/10 17:45:31.060310 zmdc[3763].INF ['zmc -m 9' starting at 10/04/10 17:45:31, pid = 3855]
10/04/10 17:45:31.060826 zmdc[3763].INF [Starting pending process, zmc -m 7]
10/04/10 17:45:31.061716 zmdc[3763].INF ['zmc -m 7' starting at 10/04/10 17:45:31, pid = 3856]
10/04/10 17:45:31.263469 zmdc[3763].ERR ['zmc -m 9' exited abnormally, exit status 255]
10/04/10 17:45:31.347464 zmdc[3763].ERR ['zmc -m 7' exited abnormally, exit status 255]
10/04/10 17:45:50.089437 zmdc[3763].INF [Starting pending process, zmc -m 8]
10/04/10 17:45:50.090555 zmdc[3763].INF ['zmc -m 8' starting at 10/04/10 17:45:50, pid = 3860]
10/04/10 17:45:50.406654 zmdc[3763].ERR ['zmc -m 8' exited abnormally, exit status 255]
10/04/10 17:45:51.008342 zmdc[3763].INF [Starting pending process, zmc -m 9]
10/04/10 17:45:51.009440 zmdc[3763].INF ['zmc -m 9' starting at 10/04/10 17:45:51, pid = 3862]
10/04/10 17:45:51.009938 zmdc[3763].INF [Starting pending process, zmc -m 7]
10/04/10 17:45:51.010784 zmdc[3763].INF ['zmc -m 7' starting at 10/04/10 17:45:51, pid = 3863]
10/04/10 17:45:51.202705 zmdc[3763].ERR ['zmc -m 9' exited abnormally, exit status 255]
10/04/10 17:45:51.220074 zmdc[3763].ERR ['zmc -m 7' exited abnormally, exit status 255]
10/04/10 17:46:30.004330 zmdc[3763].INF [Starting pending process, zmc -m 8]
10/04/10 17:46:30.005538 zmdc[3763].INF ['zmc -m 8' starting at 10/04/10 17:46:30, pid = 3866]
10/04/10 17:46:30.098361 zmdc[3763].ERR ['zmc -m 8' exited abnormally, exit status 255]
10/04/10 17:46:31.000512 zmdc[3763].INF [Starting pending process, zmc -m 9]
10/04/10 17:46:31.001642 zmdc[3763].INF ['zmc -m 9' starting at 10/04/10 17:46:31, pid = 3868]
10/04/10 17:46:31.002141 zmdc[3763].INF [Starting pending process, zmc -m 7]
10/04/10 17:46:31.002990 zmdc[3763].INF ['zmc -m 7' starting at 10/04/10 17:46:31, pid = 3869]
10/04/10 17:46:31.245401 zmdc[3763].ERR ['zmc -m 9' exited abnormally, exit status 255]
10/04/10 17:46:31.261088 zmdc[3763].ERR ['zmc -m 7' exited abnormally, exit status 255]
10/04/10 17:47:50.060541 zmdc[3763].INF [Starting pending process, zmc -m 8]
10/04/10 17:47:50.061651 zmdc[3763].INF ['zmc -m 8' starting at 10/04/10 17:47:50, pid = 3880]
Any idea??
whatboy
Post by whatboy »
Did you execute as root...
sysctl -p
ipcs -l
and restarted Zoneminder???
jorgus
Post by jorgus »
Yes, I have restarted zoneminder, but dont work. I have 2GB ram.
[root@camaras ~]# sysctl -p
net.ipv4.ip_forward = 0
net.ipv4.conf.default.rp_filter = 1
net.ipv4.conf.default.accept_source_route = 0
kernel.sysrq = 0
kernel.core_uses_pid = 1
error: "net.bridge.bridge-nf-call-ip6tables" is an unknown key
error: "net.bridge.bridge-nf-call-iptables" is an unknown key
error: "net.bridge.bridge-nf-call-arptables" is an unknown key
[root@camaras ~]# ipcs -l
---- Límites memoria compartida ----
max number of segments = 4096
max seg size (kbytes) = 250000
max total shared memory (kbytes) = 1024000000
tamaño mín. segmento (bytes) = 1
------ Límites semáforo --------
número máximo de matrices = 128
máx. semáforos por matriz = 250
máx. semáforos sistema = 32000
máx. oper. por llamada semop = 32
valor máx. semáforo = 32767
------ Mensajes: límites -------
máx. colas sistema = 3995
tamaño máx. mensaje (bytes) = 8192
tamaño máx. predeterminado cola (bytes) = 16384
11/04/10 17:35:30.295239 zmwatch[3584].ERR [Can't get shared memory id '7a6d0005', 5: No existe el fichero o el directorio]
11/04/10 17:35:30.295557 zmwatch[3584].ERR [Can't get shared memory id '7a6d0006', 6: No existe el fichero o el directorio]
11/04/10 17:35:30.296103 zmwatch[3584].ERR [Can't get shared memory id '7a6d0008', 8: No existe el fichero o el directorio]
11/04/10 17:35:40.298259 zmwatch[3584].ERR [Can't get shared memory id '7a6d0006', 6: No existe el fichero o el directorio]
11/04/10 17:35:40.298774 zmwatch[3584].ERR [Can't get shared memory id '7a6d0008', 8: No existe el fichero o el directorio]
11/04/10 17:35:50.301009 zmwatch[3584].ERR [Can't get shared memory id '7a6d0006', 6: No existe el fichero o el directorio]
11/04/10 17:35:50.301532 zmwatch[3584].ERR [Can't get shared memory id '7a6d0008', 8: No existe el fichero o el directorio]
11/04/10 17:36:00.303856 zmwatch[3584].ERR [Can't get shared memory id '7a6d0008', 8: No existe el fichero o el directorio]
11/04/10 17:35:34.339214 zmdc[3515].ERR ['zmc -m 5' exited abnormally, exit status 255]
11/04/10 17:36:14.021201 zmdc[3515].INF [Starting pending process, zmc -m 5]
11/04/10 17:36:14.022555 zmdc[3515].INF ['zmc -m 5' starting at 10/04/11 17:36:14, pid = 3644]
11/04/10 17:36:14.023086 zmdc[3515].INF [Starting pending process, zmc -m 6]
11/04/10 17:36:14.024201 zmdc[3515].INF ['zmc -m 6' starting at 10/04/11 17:36:14, pid = 3645]
11/04/10 17:36:14.025045 zmdc[3515].INF [Starting pending process, zmc -m 8]
11/04/10 17:36:14.026519 zmdc[3515].INF ['zmc -m 8' starting at 10/04/11 17:36:14, pid = 3646]
11/04/10 17:36:14.182969 zmdc[3515].ERR ['zmc -m 8' exited abnormally, exit status 255]
11/04/10 17:36:14.256914 zmdc[3515].ERR ['zmc -m 6' exited abnormally, exit status 255]
11/04/10 17:36:14.279704 zmdc[3515].ERR ['zmc -m 5' exited abnormally, exit status 255]
11/04/10 17:37:34.042958 zmdc[3515].INF [Starting pending process, zmc -m 5]
11/04/10 17:37:34.044355 zmdc[3515].INF ['zmc -m 5' starting at 10/04/11 17:37:34, pid = 3650]
11/04/10 17:37:34.045026 zmdc[3515].INF [Starting pending process, zmc -m 6]
11/04/10 17:37:34.046576 zmdc[3515].INF ['zmc -m 6' starting at 10/04/11 17:37:34, pid = 3651]
11/04/10 17:37:34.047165 zmdc[3515].INF [Starting pending process, zmc -m 8]
11/04/10 17:37:34.048411 zmdc[3515].INF ['zmc -m 8' starting at 10/04/11 17:37:34, pid = 3652]
11/04/10 17:37:34.162934 zmdc[3515].ERR ['zmc -m 8' exited abnormally, exit status 255]
11/04/10 17:37:34.261450 zmdc[3515].ERR ['zmc -m 5' exited abnormally, exit status 255]
11/04/10 17:37:34.273861 zmdc[3515].ERR ['zmc -m 6' exited abnormally, exit status 255]
Jorge
kingofkya
Post by kingofkya »
put
admin:airlive@192.168.1.101/mjpg/video.mjpg?resolution=vga
in firefox address bar does it work? Can you see image?
Also you english is fine.
jorgus
Post by jorgus »
I have 4 types of IP cameras:
POE-100CAMv2 http://www.airlive.com/product /product_3.jsp?pdid=PD1244146254786 Camera ID 5
This one does not work in firefox http://192.168.1.230/mjpg/video.mjpg?resolution=vga show this error: "The requested URL /mjpg/video.mjpg was not found on this server".
But it works with http://192.168.1.230/jpg/image.jpg for a still image. In zoneminder dont work, then I set the resolution in the camera in 352x240 in firefox http://192.168.1.230/cgi-bin/admin/para ... on=352x240 and this work in zoneminder, But dont work perfectly, and it continues generating log error. If I increase the resolution of the camera the same error appears and dont have image.
12/04/10 08:09:17.389827 zmwatch[3646].ERR [Can't get shared memory id '7a6d0005', 5: No existe el fichero o el directorio]
12/04/10 08:09:17.390118 zmwatch[3646].ERR [Can't get shared memory id '7a6d0006', 6: No existe el fichero o el directorio]
12/04/10 08:09:17.390543 zmwatch[3646].ERR [Can't get shared memory id '7a6d0008', 8: No existe el fichero o el directorio]
POE-200CAMv2 http://www.airlive.com/product/product_ ... 4408465073 Camera ID 6
Same as POE-100CAMv2
WL-1000CAM http://www.airlive.com/product/product_ ... 7461639522 Camera ID 7
Same as POE-100CAMv2, but work perfectly.
OD-600HD http://www.airlive.com/product/product_ ... 4263676386
In firefox work "http://192.168.1.232/mjpg/video.mjpg?resolution=vga". In zoneminder It does not work with any tried configuration.
I thing the problem is only with the shared memory, how a increase the shared memory to 1gb ram?
thanks
curtishall
Post by curtishall »
thanks
There's only about one thousand posts about this. Why don't you read the WIKi / FAQ? This is the number one Zoneminder issue.
Curtis Hall
Bluecherry
www.bluecherrydvr.com
store.bluecherry.net
jorgus
Post by jorgus »
yes, I find:
1024mb x 1024kb x 1024byte = 1073741824 bytes
	kernel.shmall = 1073741824
	kernel.shmmax = 1073741824
thanks
