PV-149P freezes system completely [solved]
alinkenbach
Post by alinkenbach »
Hello
I bought on of the legendary bluecherry PV149 which is nicely recognised and works out of the box apart from one thing: after a few seconds of grabbing it entirely freezes up the system. Has anyone heard of this before or should I suspect defective hardware?
Suse 11.1 dual Opteron 64
Linux version 2.6.27.23-0.1-default #1 SMP
Asus motherboard, 4G of registered first class ram fully tested,
I tried the card with mplayer as well with the same freezes happeneing. If I use my pinnacle dazzle Dv100 grabbing works fine with both zm and mplayer.
HELP!
thanks
alex
following a few 'famous last words' from /var/log/messages:
Jul 18 16:11:47 mother kernel: BUG: unable to handle kernel paging request at ffff8800d1b0acc9
Jul 18 16:11:47 mother kernel: IP: [<ffffffff802ab39b>] free_block+0x75/0x126
Jul 18 16:11:47 mother kernel: PGD 202063 PUD 0
Jul 18 16:11:47 mother kernel: Oops: 0002 [1] SMP
Jul 18 16:11:47 mother kernel: last sysfs file: /sys/devices/system/cpu/cpu1/cache/index2/shared_cpu_map
Jul 18 16:11:47 mother kernel: CPU 1
Jul 18 16:11:47 mother kernel: Modules linked in: ip6t_LOG xt_tcpudp xt_pkttype ipt_LOG xt_limit nfsd lockd nfs_acl auth_rpcgss sunrpc exportfs binfmt_misc snd_pcm_oss snd_mixer_oss snd_seq_midi snd_seq_midi_event snd_seq ip6t_REJECT nf_conntrack_ipv6 ip6table_raw xt_NOTRACK ipt_REJECT xt_state iptable_raw iptable_filter ip6table_mangle nf_conntrack_netbios_ns nf_conntrack_ipv4 nf_conntrack ip_tables ip6table_filter ip6_tables x_tables ipv6 cpufreq_conservative cpufreq_userspace cpufreq_powersave powernow_k8 nls_iso8859_1 nls_cp437 vfat fat fuse loop dm_mod snd_mpu401 rtc_cmos tda1004x(N) ppdev snd_mpu401_uart rtc_core ns558 rtc_lib joydev gameport pcspkr k8temp(N) tg3 nvidia(PX) libphy bttv budget_av(N) ir_common compat_ioctl32 i2c_algo_bit saa7146_vv v4l2_common btcx_risc videobuf_dma_sg tveeprom videobuf_core videodev v4l1_compat parport_pc parport floppy snd_usb_audio snd_intel8x0 budget_core(N) ohci1394 snd_ac97_codec snd_usb_lib dvb_core(N) cfi_cmdset_0002(N) cfi_util(N) ac97_bus ieee1394 jedec_probe(N) i2
Jul 18 16:11:47 mother kernel: c_nforce2 saa7146 cfi_probe(N) button gen_probe(N) snd_rawmidi ttpci_eeprom(N) snd_pcm snd_seq_device snd_timer ck804xrom(N) shpchp i2c_core snd_hwdep snd mtd pci_hotplug soundcore chipreg(N) snd_page_alloc usblp map_funcs(N) usbhid usb_storage hid sr_mod cdrom ff_memless sg raid456 async_xor async_memcpy async_tx xor raid0 sd_mod ehci_hcd crc_t10dif ohci_hcd usbcore edd raid1 ext3 mbcache jbd fan ide_pci_generic amd74xx ide_core ata_generic pata_amd sata_sil sata_nv libata scsi_mod dock thermal processor thermal_sys hwmon
Jul 18 16:11:47 mother kernel: Supported: No
Jul 18 16:11:47 mother kernel: Pid: 5185, comm: plasma Tainted: P 2.6.27.23-0.1-default #1
Jul 18 16:11:47 mother kernel: RIP: 0010:[<ffffffff802ab39b>] [<ffffffff802ab39b>] free_block+0x75/0x126
Jul 18 16:11:47 mother kernel: RSP: 0018:ffff880070475d48 EFLAGS: 00010002
Jul 18 16:11:47 mother kernel: RAX: ffff88009a952000 RBX: ffff88007fc92b80 RCX: ffff8800bf8210c0
Jul 18 16:11:47 mother kernel: RDX: ffff8800d1b0acc1 RSI: ffff8800904ae000 RDI: ffff8800904aed98
Jul 18 16:11:47 mother kernel: RBP: ffff8800904aed98 R08: ffff8800bf820000 R09: ffff8800bf0d7818
Jul 18 16:11:47 mother kernel: R10: ffff88008121c548 R11: 0000000000000000 R12: 000000000000000d
Jul 18 16:11:47 mother kernel: R13: ffff8800bf0d7880 R14: 000000000000020d R15: 000000000000003c
Jul 18 16:11:47 mother kernel: FS: 00007f13bae64790(0000) GS:ffff8800bf05e340(0000) knlGS:0000000000000000
Jul 18 16:11:47 mother kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
Jul 18 16:11:47 mother kernel: CR2: ffff8800d1b0acc9 CR3: 000000007046f000 CR4: 00000000000006e0
Jul 18 18:45:22 mother zmdc[23477]: INF [Starting pending process, zmfilter.pl]
Jul 18 18:45:22 mother zmdc[23477]: INF ['zmfilter.pl' starting at 09/07/18 18:45:22, pid = 24848]
Jul 18 18:45:22 mother zmdc[24848]: INF ['zmfilter.pl' started at 09/07/18 18:45:22]
Jul 18 18:45:22 mother zmdc[23477]: ERR ['zmfilter.pl ' exited abnormally, exit status 9]
Jul 18 18:50:50 mother zmdc[8586]: INF ['zmc -d /dev/video' starting at 09/07/18 18:50:50, pid = 9312]
Jul 18 18:50:50 mother zmdc[9312]: INF ['zmc -d /dev/video' started at 09/07/18 18:50:50]
Jul 18 18:50:51 mother zmc_dvideo[9312]: INF [Debug Level = 0, Debug Log = <none>]
Jul 18 18:50:51 mother zmc_dvideo[9312]: INF [Starting Capture]
Jul 18 18:50:52 mother zmdc[8586]: WAR [Can't find process with command of 'zma -m 1']
Jul 18 19:36:57 mother kernel: BUG: unable to handle kernel paging request at ffff8800c7884748
Jul 18 19:36:57 mother kernel: IP: [<ffffffff802ab39b>] free_block+0x75/0x126
Jul 18 19:36:57 mother kernel: PGD 202063 PUD 0
Jul 18 19:36:57 mother kernel: Oops: 0002 [1] SMP
Jul 18 19:36:57 mother kernel: last sysfs file: /sys/devices/system/cpu/cpu1/cache/index2/shared_cpu_map
Jul 18 19:36:57 mother kernel: CPU 0
Jul 18 19:36:57 mother kernel: Modules linked in: ip6t_LOG xt_tcpudp xt_pkttype ipt_LOG xt_limit nfsd lockd nfs_acl auth_rpcgss sunrpc exportfs binfmt_misc snd_pcm_oss snd_mixer_oss snd_seq_midi snd_seq_midi_event snd_seq ip6t_REJECT nf_conntrack_ipv6 ip6table_raw xt_NOTRACK ipt_REJECT xt_state iptable_raw iptable_filter ip6table_mangle nf_conntrack_netbios_ns nf_conntrack_ipv4 nf_conntrack ip_tables ip6table_filter ip6_tables x_tables ipv6 cpufreq_conservative cpufreq_userspace cpufreq_powersave powernow_k8 nls_iso8859_1 nls_cp437 vfat fat fuse loop dm_mod tda1004x(N) saa7115 budget_av(N) saa7146_vv budget_core(N) cfi_cmdset_0002(N) cfi_util(N) dvb_core(N) jedec_probe(N) snd_mpu401 bttv cfi_probe(N) gen_probe(N) snd_mpu401_uart saa7146 ck804xrom(N) snd_usb_audio mtd snd_usb_lib i2c_algo_bit snd_rawmidi chipreg(N) snd_intel8x0 v4l2_common videobuf_dma_sg btcx_risc snd_ac97_codec em28xx compat_ioctl32 videodev v4l1_compat videobuf_vmalloc ppdev ac97_bus snd_seq_device videobuf_core rtc_cmos ns558 ttpci_eeprom(N)
Jul 18 19:36:57 mother kernel: usblp snd_pcm ir_common shpchp snd_timer snd_hwdep tg3 usb_storage sr_mod rtc_core parport_pc snd floppy rtc_lib parport libphy gameport map_funcs(N) pci_hotplug tveeprom soundcore button cdrom ohci1394 sg k8temp(N) i2c_nforce2 ieee1394 pcspkr nvidia(PX) snd_page_alloc i2c_core joydev usbhid hid ff_memless raid456 async_xor async_memcpy async_tx xor raid0 ehci_hcd sd_mod ohci_hcd crc_t10dif usbcore edd raid1 ext3 mbcache jbd fan ide_pci_generic amd74xx ide_core ata_generic pata_amd sata_sil sata_nv libata scsi_mod dock thermal processor thermal_sys hwmon
Jul 18 19:36:57 mother kernel: Supported: No
Jul 18 19:36:57 mother kernel: Pid: 18466, comm: bash Tainted: P 2.6.27.23-0.1-default #1
Jul 18 19:36:57 mother kernel: RIP: 0010:[<ffffffff802ab39b>] [<ffffffff802ab39b>] free_block+0x75/0x126
mother:/home/alex # sysctl -p
fs.inotify.max_user_watches = 65536
net.ipv4.conf.default.promote_secondaries = 1
net.ipv4.conf.all.promote_secondaries = 1
kernel.shmall = 2048000
kernel.shmmax = 4194304000
mother:/home/alex # ipcs -l
------ Gemeinsamer Speicher: Grenzen --------
Maximale Anzahl der Segmente = 4096
Maximale Segmentgröße (KByte) = 4096000
Maximaler gesamter gemeinsamer Speicher (kBytes) = 8192000
Minimale Segmentgröße (Bytes) = 1
------ Semaphorengrenzen --------
maximale Anzahl von Feldern = 1024
maximale Semaphoren pro Feld = 250
maximale Semaphoren systemweit = 256000
maximale Operations pro Semop-Ruf = 32
maximaler Semaphorenwert = 32767
------ Nachrichten: Grenzen --------
maximale Warteschlangen systemweit = 1506
maximale Größe der Nachricht (Bytes) = 65536
normale maximale Größe der Warteschlange (Bytes) = 65536
Lee Sharp
Post by Lee Sharp »
The first things that come to mind are a timing problem from a non-intel chipset, or chip overheating on the card. Heat sinks will fix the one. If you can not go Intel, try turing off everything you can in the BIOS. (Printer, USB...) Then reset ESCD.
alinkenbach
The problem solved by selcting v4l version 1 instead of 2.
