Trendnet TV-IP110
alexolait
Trendnet TV-IP110
Post by alexolait » Tue Apr 28, 2009 4:00 pm
I have an TV-IP110 trendnet camera but shz doesn't work with ZM.
Can someone tell me if she is compatible with zm and if yes how do i must do ??
Thanks a lot
for information, I have tested this config with my camera:
Remote host name : my ip adress
Remote Host Path : /cgi/jpg/image.cgi
capture width : 640
capture height : 480
in zmwatch.log, i have this message :
Can't get shared memory id '7a6d0005', 5: No such file or directory
thanks for your help
MrEvoMan
Post by MrEvoMan » Tue Apr 28, 2009 4:14 pm
I don't think that error has anything to do with the camera...
Appears to be something setup incorrectly with your Shared Memory location.
alexolait
Post by alexolait » Tue Apr 28, 2009 10:52 pm
It's ok, i have solved my problem using user:pasword@192.168.1.222 in host and /cgi/jpg/image.cgi in Remote Host Path
The problem was the authentification :oops:
Now my TV-IP110 Trendnet works well!
:D
Renato
Post by Renato » Tue Jun 30, 2009 6:21 pm
I bought two TV-IP110 and I used same config, but they doesn't worked :(
Did I forgot anything?
[]s,
Renato Pinheiro
www.gpi.ufrj.br
alexolait
Post by alexolait » Wed Jul 01, 2009 2:51 pm
in the source tab, put the login and password and the ip of your camera
example: admin:admin@192.168.1.x
Renato
Post by Renato » Wed Jul 01, 2009 3:15 pm
But I already did that, did you see my 2nd picture? In the Remote Hostname Field I put: my_username:my_password@my_ip_address.
P.S.: In picture I changed real data to fake data for security reasons ;)
[]s,
Renato Pinheiro
www.gpi.ufrj.br
kingofkya
Post by kingofkya » Thu Jul 02, 2009 12:54 am
see docs about shared memory
alexolait
Post by alexolait » Thu Jul 02, 2009 11:02 am
Is java installed on your pc ?
kingofkya
Post by kingofkya » Thu Jul 02, 2009 8:28 pm
one is aready working
Renato
Post by Renato » Wed Jul 08, 2009 7:32 pm
[SOLVED]
Apparently the problem was the shared memory, after increase it and reduce max frame to 10 and buffer to 100, works fine.
[]s,
Renato Pinheiro
www.gpi.ufrj.br
Users browsing this forum: No registered users and 11 guests
