Problems with grandtec grand ip camera plus[resolved]
hmcinfo
Post by hmcinfo » Thu May 29, 2008 3:39 pm
i try to install the GRANDTEC ip camera plus on Zoneminder but no video appears.
Remote Host Name IPcam-01
Remote Host Port 80
Remote Host Path http://user:pass@ip/video.cgi
(Also,i have tried with http://user:pass@ip/still.jpg)
-firefox
http://user:pass@ip/video.cgi ok
in VLC with the same URL ok
with wget http://user:pass@ip/still.jpg ok i capture one view
with wget http://user:pass@ip/video.cgi
--myboundary^M
Content-Type: image/jpeg^M
Content-Length: 019648^M
Content-Auth: 0F483F0B32ADD09^M
in zmdc.log
05/29/08 17:31:24.907261 zmdc[5171].INF ['zmc -m 10' starting at 08/05/29 17:31:24, pid = 8356]
05/29/08 17:31:24.957913 zmdc[5171].ERR ['zmc -m 10' exited abnormally, exit status 255]
Please, help me!
Thanks.
cordel
Re: Problems with grandtec grand ip camera plus
Post by cordel » Thu May 29, 2008 9:38 pm
hmcinfo wrote: Remote Host Name IPcam-01
Remote Host Port 80
Should be :
Remote Host Name user:pass@ip
Remote Host Port 80
Remote Host Path video.cgi
And the camera name is defined under the first tab.
hmcinfo
Post by hmcinfo » Fri May 30, 2008 11:49 am
thanks for your proposition but it is not good
Already the same problem
cordel
Post by cordel » Fri May 30, 2008 5:19 pm
Okay, so raise your debug level and see what the logs say.
hmcinfo
Post by hmcinfo » Mon Jun 02, 2008 8:35 am
thanks a lot
it works!
the good configuration is:
Remote Host Port 80
Remote Host Path /video.cgi "don't forget /"
ynn
Post by ynn » Fri Aug 01, 2008 3:19 pm
what do you think of the camera so far, is it good camera?do you have problem with the camera? because i am planing to buy this camera and put it outdoor with my own housing, so i need to know if this camera durable enough with constant heat
thanks.
Users browsing this forum: No registered users and 8 guests
