I have a Bluecherry PV-183-16 card with a number of cameras attached - the software install is using Bluecherry's LiveCD with ZoneMinder 1.22.3.
The system is working if I configure the Device Format to be Auto and the Capture Palette to RGB24 - however this only gives me B/W pictures. If I set the Device Format to PAL (same as the colour cameras) then I get corrupt images (like a badly tuned TV)
Capture Width / Height set to 320/240 (doesn't like anything higher).
Any one have any suggestions on getting colour to work or am I stuck with B/W only?
