Help with cheap ASF-MPEG4 ip cam
aNt1X
Post by aNt1X »
Dear users,
i'm currently using some webcam identical to the A-LINKING AAL 9684.
It supports 2 view modes:
http://ip/img/video.asf (used by ActiveX)
http://ip/img/video.jpg
I can point correctly ZoneMinder to the video.jpg image, and it shows correctly, with obviously very poor refresh time. Obviously if i point ZoneMinder to video.asf, it doesn't work.
I'm still not able to view the ASF file.
If i point the ASF directly with TCPMP, it shows it correctly, and the informations provided are:
VIDEO: M4S2
Codec: MPEG4 DivX/XviD
Dimensions: 320x240
I tried the howto provided here
http://www.zoneminder.com/forums/viewtopic.php?t=10766, but i still have problems: it seems that ffmpeg can't recognize the format.
If i run ffmpeg via command line without parameters, i have this error:
root@videoserver:~# ffmpeg -i http://192.168.1.220/img/video.asf
FFmpeg version SVN-rUNKNOWN, Copyright (c) 2000-2007 Fabrice Bellard, et al.
  configuration: --enable-gpl --enable-pp --enable-swscaler --enable-pthreads --enable-libvorbis --enable-libtheora --enable-libogg --enable-libgsm --enable-dc1394 --disable-debug --enable-shared --prefix=/usr
  libavutil version: 1d.49.3.0
  libavcodec version: 1d.51.38.0
  libavformat version: 1d.51.10.0
  built on Jun  3 2007 20:59:25, gcc: 4.1.3 20070528 (prerelease) (Ubuntu 4.1.2-9ubuntu2)
http://192.168.1.220/img/video.asf: Error while opening file
root@videoserver:~#         '
but the video.asf is reachable, because if i use WGET it starts downloading the stream:
root@videoserver:~# wget http://192.168.1.220/img/video.asf
--15:43:05--  http://192.168.1.220/img/video.asf
           => `video.asf.1'
Connecting to 192.168.1.220:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: unspecified [application/octet-stream]
    [             <=>                     ] 26,645         7.76K/s
root@videoserver:~#
What can i do? I have these 10 webcams installed, my customer is viewing them via ActiveX, but i would like to view them via ZoneMinder, and use the ZoneMinder motion detection feature.
Thank you very much,
cordel
Post by cordel »
You have to use jpeg, ZM does not support mpeg, avi, asf capturing as they are patent encumbered.
aNt1X
Post by aNt1X »
cordel wrote:You have to use jpeg, ZM does not support mpeg, avi, asf capturing as they are patent encumbered.
i cannot even use the ffmpeg tool ?
i have a problem with this webcam. this ipcam has a limit of 4 simultaneous viewer.
it seems that if i use the ipcam in jpeg mode and activate Zoneminder, it seems that the webcam immediately reaches the limit, thus locking the webcam: the image doesn't refresh anymore, until i reboot the webcam.
any suggestion? i thought that using the ffmpeg decoder i was able to use Zoneminder ...
thank you very much
aNt1X
agoodm
Post by agoodm »
Try lowering the frame rate of the monitor to about 2 fps.
aNt1X
Post by aNt1X »
Ok,
i had to recompile ffmpeg.
The version installed with "apt-get install zoneminder" wasn't able to open the asf stream.
I downloaded and compiled the latest svn version, and now i am able to convert the ASF stream to raw video with
ffmpeg -i http://192.168.1.220/img/video.asf -f rawvideo -pix_fmt rgb24 - | ./vpipe -f rgb -i 0
and point the Zoneminder monitor to /dev/video1
Thank you very much
aNt1X
