Linksys WVC54GCA
big brother
Linksys WVC54GCA
Post by big brother » Thu Jan 24, 2008 2:52 pm
is this Camera working with ZoneMinder ?
Linksys WVC54GCA
http://www.linksys.com/servlet/Satellit ... 1687048B01
greetz
big brother
cordel
Post by cordel » Thu Jan 24, 2008 7:16 pm
Not sure anyone has tryed that paticular one.
http://www.google.com/search?hl=en&safe ... tnG=Search
NewTechFool
Post by NewTechFool » Sun Apr 06, 2008 5:27 pm
I was able to configure the camera and make it work with Zone Minder.
As you can see I configured it for 10 fps, but ZM is reporting between 0.5 and 1.0 fps. When you load the image in the browser you can also tell that the camer is just very slow. It's on 54Mb wireless close the the router, so I should be able to get close to full speed. I think the camera is just too slow.
There also seems to be a lot of noise in the image, so adjusting the motion detection is tricky. Have not found a good setting yet that does not get false positives and at the same time captures motion when it happens.
I disabled authentication in the camera itself, as it is on my internal network. Not sure how you would pass credentials from ZM to the camera if you wanted to enable security on the camera.
I can't recommend the camera because of the speed of capture and the image quality.
Here are my settings:
jameswilson
Post by jameswilson » Sun Apr 06, 2008 8:08 pm
if you check the forum it is littered with similar comments about linksys cameras
James Wilson
eug
Post by eug » Thu Apr 09, 2009 6:18 am
It has been a year now ... do you still feel the same? Have there been any firmware updates or anything that fixes it?
obagi
Post by obagi » Sat Aug 22, 2009 5:59 am
I am getting 10fps in 640x480 from this camera in zm.
My setting for remote host path is /img/video.mjpeg
eug
Post by eug » Sat Aug 22, 2009 6:01 am
Hmm 10fps at 640x480 isn't bad at all. Is it stable? Keeps on running and running?
obagi
Post by obagi » Sat Aug 22, 2009 7:03 am
It's been running for the last 24hrs no problem. The picture quality is terrible though. I am going to return this camera back to my local Fry's store.
eug
Post by eug » Sat Aug 22, 2009 7:05 am
ahh.. damn.. so close!
Is it bad during daylight, or just at night?
obagi
Post by obagi » Sat Aug 22, 2009 7:35 am
This camera is bad - day or night. Lots of screen artifacts make motion detection impossible. You could use it for a monitor if you already have one and can not return it.
Users browsing this forum: No registered users and 11 guests
