mobotix cameras
ynn
mobotix cameras
Post by ynn »
did anyone use mobotix camera here? I read in the website that mobotix have its build in recording software and we do not need to pay extra.how good is the software and the cameras it self, is it true that mobotix using very low bandwidth and low size of file using its mxpeg.
thanks.
cordel
Post by cordel »
I did a little research on them, and the Mxpeg is just a modified mjpeg stream that so far seems not at all compatible with ZM because they add a ton of extra header information. As far as there software, never used it so I don't know.
ynn
Post by ynn »
Cordel,
thanks for the reply, I saw the demo cameras and it looks quite good, stream fast and high resolution, what do you think about theirs cameras compare to axis cameras ?
thanks.
Lee Sharp
Post by Lee Sharp »
Seeing as how they will not work at all with our application; poorly. :)
