Unable to go 'Back' to Search results
This is the place for any problems or issues with the website in general or the new forums in particular.
nigelgiddings
Post by nigelgiddings »
Not sure if I am being thick but when I do a search I tend to read a thread and then use the @back' button in IE6 to return to the search results. I find it is the easiest way to look through the many matches you typically get.
However, on this board I get 'Page hase expired' rather than the search list... is this intentional, am I doing something wrong, am I the only one ?
Nigel
Linux Newbie...
jameswilson
Post by jameswilson »
use fire fox i think this is an ie issue as it happens to me too, not just here thought
James Wilson
cordel
Post by cordel »
The search is not added as part of the URL so using the back button will not work.
You can hold down the shift key when you click a link and it will open in a new window.
Regards,
Cordel
zoneminder
Site Admin
Post by zoneminder »
I'm on FireFox and it works fine for me but in IE I have to hit F5 to refresh the page. I don't know that there is a lot I can do about it I'm afraid.
Phil
nigelgiddings
Thanks, the Shift key it is then...
Cordel,
Thanks for the suggestion, using the shift key is a great tip...
Nigel
Linux Newbie...
