Number of Cameras
calixto
Number of Cameras
Post by calixto »
How feasible is it to setup ZM with 32 cameras? using which video cards?
Thanks for the heads up
Calixto
Ruler
Post by Ruler »
I have it set up with 16 using 2 spectra-8 cards. Theoretically you can use up to 4 boards in one PC, so you could use up to 32 cameras in a single machine. I'd think you'd run into problems with bus transfer speed, bandwidth, memory, etc though. You'd also need one hell of a machine, both case and motherboard, to house all that crap. (4 boards, 4 expansion cards, IDE controllers for more hard drives - right there you're talking 8 PCI slots and 4 more back slots available for the secondary input expansion boards.
This message is made up of not less than 90% recycled electrons.
Flash_
Post by Flash_ »
Using network cams would get around those restrictions, but introduce more in the way of cpu load.
That said, I imagine you could get 32 cams on one fairly high spec single or multiple cpu pc if you restricted the fps down to 1 or 2 per cam, went b&w and reduced image size and did record-only instead of modect.
Otoh, in my experience Zoneminder does odd things when handling > 10 cams in handling states etc, but that can be got around.
