Ubuntu 18.04: MySQL or MariaDB for Zoneminder
ScottBouch
Post by ScottBouch »
As per the title, I'm just setting up a new install of Ubuntu 18.04 and have come to install Zoneminder.
I have the choice of MariaDB or MySQL, but don;t know which to go for.
Are there any pro's / cons to Zoneminder as to which one I go for?
Cheers, Scott.
SteveGilvarry
Re: Ubuntu 18.04: MySQL or MariaDB for Zoneminder
Post by SteveGilvarry »
Don't think it makes much of a difference at the moment, I think most head towards MariaDB, but that could be more a philosophy choice that features.
Mariadb seems to work better for me. Had to replace a 17 camera server a while back and went with Bionic and Mariadb. System seems to use less memory than with MySQL.
hunnymonster
Post by hunnymonster »
Echo the above. Migrated a server from mySQL 5.7 to MariaDB 10.1 and on to 10.3.12 on Ubuntu 18.04 and load dropped from ~1.5 to ~0.7 same camera analysing similar scenes
f.eichentopf
Post by f.eichentopf »
@hunnymonster have you some tips howto migrate from mysql to mariadb?
hunnymonster
Not really - I simply installed the Ubuntu-bundled MariaDB (10.1 train) which took care of the MySQL - MariaDB change, then added the MariaDB PPA for the 10.3 train and upgraded.
Take a backup before you start, I'm not taking the blame if your installation breaks :mrgreen:
Eiserfeyer
Post by Eiserfeyer »
Is it also possible to use InfluxDB instead of MySQL or MariaDB while using ZM???
