TuxWang 3003-USFBA Support
aindilis
Post by aindilis » Sat Jun 02, 2018 7:03 pm
I recently bought 2 of these cameras based on a deal from slickdeals.net that offered them for $15 each:
https://www.amazon.com/TUXWANG-Security ... B0754KCTSH
I didn't realize it would not make available to me the RTSP login. So I am having trouble getting it to work with VLC or ZoneMinder.
Per this thread: https://www.use-ip.co.uk/forum/threads/ ... elnet.938/
I tried ONVIF Device Manager https://sourceforge.net/projects/onvifdm/
That was able to control the PTZ features, but could not get a stream, saying No Signal. It had listed admin/12345 as a password, I wasn't sure if that meant it was for the camera. But trying various means to login to rtsp all failed.
Any help would be appreciated because $15 for a camera with a 120-degree fish eye 1080p w/ sound and PTZ is a good deal I think. I was able to monitor the camera using the eyeplusiot.com website and the EyePlus IOT Android app. But it seems like a vendor lock in if I am unable to access the camera using other software.
Best Regards,
Andrew
aindilis
Re: TuxWang 3003-USFBA Support
Post by aindilis » Sat Jun 02, 2018 7:06 pm
Here is the deal site mention:
https://slickdeals.net/f/11625439-tuxwa ... BarV2Algo1
Note that when I applied the AH7LCEL4 coupon code it knocked off $15 instead of just $5 like the site mentions.
snake
Post by snake » Tue Jun 05, 2018 7:29 pm
See https://wiki.zoneminder.com/Finding_Camera_Stream_Paths
For $15, I don't think you can complain about not getting an RTSP path, but if you can find it let us know.
aindilis
Post by aindilis » Mon Jul 02, 2018 5:19 am
I found it. But there is a catch (see end of post).
use vlc (or whatever I'm guessing) and enter for the network stream:
rtsp://<IP>:554/onvif1
username: admin
password: <BLANK>
use onvif2 apparently to get higher res output
found following a tip from here:
Please note, I'm a little confused about whether you use rtsp:// or http://, I thought I used http:// first but now I'm using rtsp. In case that helps.
The catch is that I cannot seem to have it operate without having a connection upstream to the manufacturer, which means that I'm not sure whether the camera will still work when the trial service expires in 3 days from now. I disconnected this camera from the web service, eyeplus, and it stopped streaming. I will continue troubleshooting it.
