How to enforce low FPS in v4l2 for /dev/video0?
Posted: Wed Dec 07, 2016 10:35 pm
I am running 2 Philips SPC900NC Webcams under Debian Jessie (3.4 and 4.7 kernels). The cam is doing great in low light situations, if FPS can be reduced to 10 FPS or even 5 FPS. This works fine e.g. by recording a video with ffmpeg via:
But with surveillance tools like Motion and ZoneMinder, the cam always defaults to 15FPS - independently of any FPS rates I set in these programs. Also running "v4l2-ctl --set-parm 5" gets overwritten when Motion or ZoneMinder are started (I checked with: v4l2-ctl --get-parm).
I played with v4l2loopback and the following config is actually enforcing 5fps: /dev/video0 -> ffmpeg -> /dev/video1 -> Zoneminder. But the problem is additional CPU consumption of ffmpeg.
Is there any possibility to archive 5 FPS by enforcing the FPS in v4l2 natively (avoiding adding v4l2loopback/ffmpeg to the mix) or directly through ZoneMinder ?
P.S.: I asked the same question in stackoverflow a few days ago, but got no responses so far:
https://stackoverflow.com/questions/409 ... dev-video0
ffmpeg -f v4l2 -framerate 5 -video_size 640x480 -i /dev/video0 test.mp4
