Streaming video from BT878 card to external zonemnder server
Belekas
Post by Belekas »
I have placed two cameras in my countryside and connected to zoneminder successfully. Problem is that pc which holds zoneminder is too slow for recording, rewinding, alerting and other stuff. I have an idea to stream video from that pc with BT878 card to external VPS with zoneminder installed and use VPS for everything. What software should I use to translate from pc with BT878 card and connected cameras to VPS with zoneminder?
Thanks for your help.
abzstrak
Re: Streaming video from BT878 card to external zonemnder se
Post by abzstrak »
you should be able to do this with VLC. I'd just run vlc from the CLI from a non-gui version of Linux (to keep the overhead down). You should be able to use VLC to turn the video into an RTSP stream.
