I dont know how manny of you have had issuse with zm/apache being slow and just dropping frequently form flipping though events.Lingerd is a daemon (service) designed to take over the job of properly closing network connections from an http server like Apache.
Because of some technical complications in the way TCP/IP and HTTP work, each Apache process currently wastes a lot of time "lingering" on client connections, after the page has been generated and sent. Lingerd takes over this job, leaving the Apache process immediately free to handle a new connection. As a result, Lingerd makes it possible to serve the same load using considerably fewer Apache processes. This translates into a reduced load on the server.
Lingerd is particularily useful in Apache webservers that generate dynamic pages (e.g in conjunction with mod_perl, mod_php or Java/Jakarta/Tomcat).
More importantely, lingerd can only do an effective job if HTTP Keep-Alives are turned off; since keep-alives are useful for images, the recommended lingerd setup is to have an Apache/mod_whatever/lingerd server for the dynamic pages, and a plain Apache (or thttpd or boa) for the images.
I have a solution and its really easy don't be scared of the compiler
First make a build directory
mkdir build
cd build
wget http://images.iagora.com/media/software/lingerd/lingerd-0.94.tar.gz
tar zxf lingerd-0.94.tar.gz
cd lingerd-0.94
make
cp lingerd /usr/bin/lingerd
chmod a+x /usr/bin/lingerd
my solution is just add it to apaches rc.d or init.d file (note this will differ per distro.)
On arch linux
nano /etc/rc.d/httpd
##EDIT START
##EDIT END
case "$1" in
start)
stat_busy "Starting Apache Web Server"
##EDIT Start
/usr/bin/lingerd
##EDIT END
if $APACHECTL start &>/dev/null ; then
add_daemon $daemon_name
stat_done
else
stat_fail
exit 1
fi
stop)
stat_busy "Stopping Apache Web Server"
##EDIT START
pkill lingerd
##EDIT END
if $APACHECTL stop &>/dev/null ; then
rm_daemon $daemon_name
stat_done
else
stat_fail
exit 1
fi
httpd.conf and turn off keep alive other wise all that work would be for nothing.
Now you can take back all that mem httpd was wasting.
