ANPVIZ - IPC-D250W-S
Maximo1970
Post by Maximo1970 »
I've just bought one of these cameras to add to my setup. This is my first IP Camera, all of my other camera's are attached to a DVR at present.
For those of you that are looking at this camera and want to use it with ZoneMinder there are two video streams available.
Hi-Res (5MP)
rtsp://IPADDRESS/stream0
Lo-Res (D1)
rtsp://IPADDRESS/stream1
I've set both streams to be VBR instead of the default CBR, which has reduced the bandwidth to a more acceptable level. It was running at around 20Mbps with CBR, using VBR it's around 8Mbps.
