Page 1 of 1
AXIS P1357-E
Posted: Wed Dec 11, 2019 1:06 pm
by andrea.vescovo
i have to buy a lot of AXIS P1357-E cameras. I want to be sure they are fully compatible with zoneMinder. Anyone have try them? there are some problem?
Re: AXIS P1357-E
Posted: Wed Dec 11, 2019 6:41 pm
by snake
Might need to buy one used online to 100% confirm they work.
This brand is generally well supported. I looked at the user manual for the P1357 and it indicates it has Onvif, and RTSP (H264) / MJPEG, so I think it's very likely to work. But, I didn't see an actual path in the manual... Check ispy.
