Page 1 of 1
poe ip outdoor cam for zoneminder
Posted: Mon Jun 10, 2019 8:34 am
by drforbin6
Could anyone suggest an inexpensive compatible ip poe cam for zoneminder?
I need some advice. I'm trying a rlc-410, is it onvif compliant? will it work?
Thank you all
Re: poe ip outdoor cam for zoneminder
Posted: Tue Jun 11, 2019 9:36 pm
by iconnor
There are some issues with the rlc-410s but we have figured them out. They do work.
chinese cameras are cheaper and work fine, but you will have to deal with really crappy non-english web ui's.
Just about anything poe will work with ZoneMinder. As long as it isn't a proprietary cloud only camera.
