Zmodo
dhenzler
Zmodo
Post by dhenzler » Mon Oct 23, 2017 2:12 am
I have an 8 cam Zmodo IP CAM system. Will this work with that? As well can ZM be configured to work to a Lorex Internet IP that has proper ports open to provide cam video. I was using Lorex viewer, but that is only supported on Winderz.
Help !
I get these errors when attempting to see a cam...
SQL-ERR 'SQLSTATE[HY000]: General error: 1366 Incorrect integer value: '' for column 'V4LMultiBuffer' at row 1', statement was 'insert into Monitors set LinkedMonitors = '', Name = 'Monitor-1', ServerId = '1', Type = 'Remote', Function = 'Monitor', Enabled = '1', RefBlendPerc = '6', AlarmRefBlendPerc = '6', AnalysisFPS = '16', MaxFPS = '16', AlarmMaxFPS = '16', Device = '/dev/video0', Channel = '0', Format = '255', Palette = '0', V4LMultiBuffer = '', V4LCapturesPerFrame = '1', Options = '', LabelFormat = '%N - %Y-%m-%d %H:%M:%S %z', LabelX = '0', LabelY = '0', LabelSize = '1', ImageBufferCount = '50', WarmupCount = '25', PreEventCount = '25', PostEventCount = '25', StreamReplayBuffer = '1000', AlarmFrameCount = '1', EventPrefix = 'Event-', SectionLength = '600', FrameSkip = '0', MotionFrameSkip = '0', AnalysisUpdateDelay = '0', FPSReportInterval = '1000', DefaultView = 'Events', DefaultRate = '100', DefaultScale = '100', WebColour = 'red', Exif = '0', SignalCheckColour = '#0000c0', Protocol = 'http', Method = 'simple', Host = 'Zmodo', Port = '80', Path = '', Colours = '3', Width = '720', Height = '480', Orientation = '0', Deinterlacing = '0', Sequence = 1'
