Light bulb cam for ZM
nycaleksey
Post by nycaleksey » Thu Sep 14, 2017 4:09 pm
Could anyone recommend a "light bulb" form factor cam for use with ZM ? Something like https://www.amazon.com/dp/B072JSLKYK or similar?
I searched the HW compatibility list on the Wiki and the web, but can't find any model that is confirmed to be supported by ZM.
Thank you!
Baylink
Re: Light bulb cam for ZM
Post by Baylink » Fri Sep 15, 2017 1:33 pm
That supports OnVIF2 discovery, and Amazon gives full return privileges; it might be worth your time to just grab one and try it. The spec list certainly makes it sound like they know what they're on about.
