Page 1 of 1
HAIWVISION AK47L7
Posted: Mon Feb 06, 2017 8:32 pm
by Sigge
Manufacturer: NVSIP
Model: NVSIP-IPC
Hardware: NVT-AK47
Device id: 3160930 / SD315082951
It is branded HAIWVISION
1080P HD IP Network Outdoor PoE Camera
Model Number:D636
It gave me serious trouble but is now working!
I had to use the bundled CMS software to set the frame rate to 5 fps.
It won't work unless you set a user name and password.
ZoneMinder setup:
Source Path rtsp://user:user@ip:554/tcp_live/ch0_0
Remote Method RTP/RTSP
Target colorspace 32 bit
Capture Width (pixels) 1920
Capture Height (pixels) 1090
Re: HAIWVISION AK47L7
Posted: Thu Oct 26, 2017 4:06 pm
by arymar
Hi Sigge, works fine for me. I used the ONVIF app to get the RSTP string to use and related details.
I have a little issue with it: I want to change the Key Frame interval and there is no option to proceed from the web interface.
Cheers
Alain
Posted: Tue Oct 31, 2017 8:54 am
by Sigge
In the end I had to set up a live555proxy to make this camera stable. That works fine.
Observe, that this cam has a SSH server that you can not change the password for. So make sure it is firewalled.
