Hello, i don't know for sure if this is the right place but anyway...
I have bought this camera, don't mean to make any advertise ( http://www.dx.com/p/cotier-ipc-631-t13- ... 7Rfy_mSxg8 ) but i find it preatty cheap for an ip cammera with 720p resolution.
Anyway i have just set it up here are the settings :
soruce type : libvlc
rtsp://camera_ip:554/live/mpeg4
resolution 1280x720 24bit
also you have to disable authentication in network - mediastream setup
a snapshot in atached file.
please excuse my poor english.
10x
COTIER IPc-631/T13
COTIER IPc-631/T13
- snapshot.jpg (204.07 KiB) Viewed 11626 times
Re: COTIER IPc-631/T13
Just as an update.
Installed this camera for some time now and it's pretty stable so far but the downside is the night vision, wich is totally useless and i mean useless I have it running outside at a range of ~15m and you cannot see anything
Thanks Littlej,
Just to add: in case you need to access the substream on such Cotier, you need to use the following:
rtsp://camera_ip:554/live/mpeg4cif
Hope this may help someone.
Cheers.
Alain
Cheers.
Alain
Hi arymar, thanks for the update.
I have updated my cotier firmware using latest version from here : http://www.en.tpsee.com/deviceupdate/95-1.html ( TH38C5/R6_ONVIF_P2P_firmware_V2.5.1.12 ) at least this suits my camera.
Since update i find the stream more stable and available at
main: rtsp://admin:psassword@ipaddress/mpeg4
sub: rtsp://admin:psassword@ipaddress/mpeg4cif
i have attached a snip from zoneminder config for my camera.
- Capture.PNG (12.49 KiB) Viewed 8941 times
update... after some time this is what happens and i have no idea how to solve it for now
i am open for suggestions.
thanks
thanks
- Capture2.PNG (271.79 KiB) Viewed 8918 times
- Capture.PNG (720.22 KiB) Viewed 8918 times
well another update
it seems that if i set the camera on CBR ( constant bit rate ) and i frame key at 15 frames and running 15 fps no more pink rubbish on the stream.
all looks good so far.
Thanks for the useful information found here.
How did you find out which FW to use ? where can I find the steps do update the FW ?
Hi, i cannot access the camera right now, but if i remember correctly you can check on the camera the hardware revision.
