Can zone minder be used on a linux box without GUI? The screen shots of how to configure it look like all the configuration must be done graphically. Is there a way to use text configuration files to do all of this?
Thanks.
Edit: I originally said on a headless linux box. What I really meant was one without a GUI.
Using ZoneMinder on a linux box without GUI
Re: Using ZoneMinder on a headless linux box
Mine are all headless. I configure them remotely using a browser.
What are you running yours on? Which version of Linux?
I'm going to edit my first post. I didn't actually mean "headless". Wrong term. I meant a version of Linux that doesn't have a graphical user interface.
I'm running Arch Linux on a Pogoplug. Would like to use it for that, but there's very scant info on how to install it, and what's out there is really dated.
Re: Using ZoneMinder on a linux box without GUI
Hi zrusr...
I don't know much about Arch Linux and Pogoplug but my setup is Ubuntu Server 12.04.2 LTS on a new, low-buget system I threw together for testing, (Elite Group ECS VX900-I motherboard, 1.6GHz, single core; 2Gb DDR 1066 RAM; OCZ Vertex 3 VTZ3 60Gb SSD). I paid 120 bucks for it and it's currently dealing well with five ip cameras and four webcams off a single, old, Pentium 4 XP PC -- the Ubuntu server with Zoneminder on it, the 5 IP cameras, and the XP machine networked on the same 100Mb switch. (Sorry, I don't know where the upper limits are for this set-up so I can't recommend it, though what I've described runs with a load of about .26 to .56, (or an upper limit of 56% of a single core processor).
Anyway, like bb99, I configure Zoneminder using a browser on another machine connected to the same network, so the server just sits there with a monitor with a blinking cursor waiting for a logon. (It'll eventually be headless.)
If you decide to go with Ubuntu, check out the distribution specific guides on the wiki. I have never had an installation of anything go so smoothly and I'm a Linux newbee! (Terminal? What?)
I can't post links yet but this is the path I took for installation guidance: Zoneminder Home > Wiki > Documentation> Contents#Distribution-specific_guides > (Contents) Distribution-specific guides > Debian / Ubuntu (click on Ubuntu) >
Ubuntu Server 12.04 64-bit with Zoneminder 1.25.0 the easy way,
Hope this helps.
Cheers!
Hope this helps.
Cheers!
Yup here also run it on Ubuntu with no graphical interface. I am pushing it a bit these days migrating over from analog (8 port card) to HD IP (running some 16 cams now). That said it a core duo server and 4Gb of memory.
Interesting mention relating to Arch Linux on the Pogoplug. I think I have seen a post of running ZM on a pogoplug here some where.
That said today I am running my sprinkler software on a seagate dockstar (similiar to the pogo plug) running ArchLinux and talking serially to two rain8net serial sprinkler controllers. Its been a couple of years and it just runs and runs with no issues.
It does have a touchscreen and web gui management interface that I utilize all of the time (like ZM's web interface).
Thinking of integrating ZM views into the Sprinkler touchscreen interface.
- PIC-today.jpg (226.07 KiB) Viewed 8200 times
Zoneminder User
Box #1 and # 2 - Intel Ubuntu 14.04 64 bit server - Most current beta 1.28 - XX HD IP cams
Box #3 - AMD Ubuntu 14.04 64 bit server - Most current beta 1.28 - XX HD IP cams
Moved rest of analogue cams to Axis Servers and Grandstream cams.
I used to ran it on a Dreamplug... 4 analog cameras connected to an IP9000 video server... cheap bastard am I??? had them running at 320*280@3~4FPS... but had a weatherstation (WView + OS WMR968) + email + DHCP + NAMED + SAMBA + WORDPRESS + GALLERY + ALOT OF SH*T... but the weather station broke (anemometer Prrrttt) so I change server... bought a google server for <$80 bucks... just stuck some Sata HDD, found some IP cameras... and I am still crancking this baster up...
