Is Dlink DCS-5635 and DCS-2130 compatible?
Have anyone got these camera up an running with Zoneminder?
Re: Is Dlink DCS-5635 and DCS-2130 compatible?
I can confirm that the DCS-2130 is compatible. You´ll have to get streams through http://user:pass@IP/videoX.mjpg.
Hi
I have successfully configured dcs 5635 thru rtsp.
But I'm unable to get the PTZ control script for the same.
Can you help.
Regards
Prasad
Can you help.
Regards
Prasad
Ive configured dlink DCS-5635 using "ffmpeg" as the source type and "rtsp://ip-address/play1.sdp" in the source path.
I use 704x576 as the capture width x height.
Im still unable to get the control script for the same. so that PTZ can be supported in the control tab.
Any luck !!
Regards
Prasad
Any luck !!
Regards
Prasad
