Chinese IP CAMERAS
lalo
Chinese IP CAMERAS
Post by lalo » Thu May 19, 2011 4:43 pm
Hello...
I found some ipcameras and i'm interested to make a zoneminder server for recording vids and make allerts in my office.
I need about 12 ipcameras and i have found a lot of cameras on chinese shops.
Can someone of you tell me if the cameras are working fine with zoneminder.
Models are
the most models you can find on aliexpress searching ip camera
Thank you all...
lalo
Re: Chinese IP CAMERAS
Post by lalo » Thu Jun 02, 2011 11:11 am
Nobody can help me?? :(
Flasheart
Post by Flasheart » Thu Jun 02, 2011 6:41 pm
Not with such a vague question. If the camera will do a static jpg image, it will work with zm.
There are literally thousands of chinese ip cams on alibaba, many with no model number or accurate specs, and I know from experience these cheap cameras sometimes change firmware without notice, so two identical cameras from different batches might have entirely different firmware, paths and capabilities.
That said, several specific models have been mentioned on these forums. Search for 'dealextreme'
lucienbouvreuil
Post by lucienbouvreuil » Fri Jul 01, 2011 2:27 pm
I bought a camera ip "EasyN FS-613A-M136" on Ebay that works with zoneminder
rdmapes
Post by rdmapes » Sun Jul 10, 2011 11:54 pm
All,
I have two that I have currently rendered useless using the wrong interface software to update parameters. Make sure you keep track of your cd's for the Chinese cameras. No I am trying to figure out how to correct the mess I have created.
Rabbit6
Post by Rabbit6 » Wed Aug 10, 2011 3:37 pm
Lalo, more info please and I may be able to help.
kingofkya
Post by kingofkya » Fri Aug 12, 2011 6:27 am
It depends unless they give you a demo camera and you try it there is no way to know. Ask most are more than willing to put a camera up for you to demo.
Qvagin
Post by Qvagin » Mon Aug 22, 2011 6:42 pm
TENVIS
EasyN
Apexis
These are the main producers of cameras provided by ebay.
I would like to see on the forum are the Chinese manufacturers of these cameras work with zoneminder.
quietas
Post by quietas » Fri Sep 16, 2011 7:07 pm
Qvagin wrote:TENVIS
EasyN
Apexis
Are any of these known to work? Tenvis, for instance, seems to have several cameras that would work for me, but unfortunately I can't seem to find any info on 'budget' IP cameras like these.
gmar_87
Post by gmar_87 » Tue Nov 15, 2011 10:07 am
kmrs75
Post by kmrs75 » Sun Feb 12, 2012 5:29 pm
I got a budget camera to work last night.
here is a link to it.
http://www.meritline.com/metal-casing-i ... 75866.aspx
therese
Post by therese » Fri Feb 24, 2012 2:24 pm
Here is one that I bought on ebay the EasyN FS-613B-M166 IP PTZ camera that works well with zoneminder.
Look at my post: "http://www.zoneminder.com/forums/viewto ... 14&t=18795"
available on ebay: "http://www.ebay.ca/itm/230681062800?ssP ... RK:null:IT"
Hope that helps.
huff
Post by huff » Mon Apr 09, 2012 5:13 pm
Hello All,
I have a few Chinese cameras and can post the model numbers but they are OEM and have not mfg name or identifier anywhere. What protocol do you use for connecting to the IP stream and what 1. Source Type, 2. Remote Protocol, 3. Remote Method, and 4. Remote Host Path are you using, or do you use for this type of camera?
If the camera's will save images via FTP is there a way to get ZM to monitor and create modetect events from this stream of contigous files?
Thanks in Advance, I appreciate your input.
Mark
