Need a recommendation
HectorG
Post by HectorG »
I am looking to build a little headless zoneminder box. What is a good compatible 4 or 8 port capture card with audio that I can purchase. I want the least amount of headaches possible but I don't want it to be real expensive. Can I eventually add another 4 port card in the future or is it better to just get an 8 port card from the beginning? I looked through compatibility list but it doesn't really say which cards are the better ones. Any advice would be appreciated. Id like the card to do the brunt of the work cause the pc wont be too fast. it will be a p4 with 1 gig of memory spare machine I have.
kmrs75
Re: Need a recommendation
Post by kmrs75 »
i have some for sale very cheap http://www.zoneminder.com/forums/viewto ... 20&t=18281
i only have ip cameras so not sure compatibility with all these but i did find this page
http://www.zoneminder.com/forums/viewto ... =geovision
