Hello, just for say
I use with relative succes
Sony SNC-CS3P camera with ZoneMinder V1.23.3 on GENTOO 64
camera firmware V1.08
only image on 320x240
640x480 (auto or field or frame) Not Work
736x544 (auto or field or frame) Not Work
idem with SNC-RZ30P firmware V3.14
and PTZ function via network do not work
when i say do not work it possible i do not configure properly devices or zm
SONY SNC-CS3P and SNC-RZ30P with ZM V1.23.3 & Gentoo 64
shm memory
Thanks for your reply
i modify values with
kernel.shmmax = 536870912
kernel.shmall = 536870912
no success with 640x480
since i reinstall the latest version of zoneminder
and now i can't have any image
i search
i search
here's how to set up the memory size depending on image size, ring buffer, etc...
http://www.zoneminder.com/wiki/index.ph ... esolutions.
pufffffffffffff
thank for your reply
i try ZM 1.24 with no success no images
i rebascule on the V1.23 and !!!! no image
with or without tune shm
my new config with your help...
kernel.shmall = 2048000
kernel.shmmax = 4194304000
hello
thanks for your reply
since i reinstall V.1.23 have an issue with apache on my gentoo 64
i need to rename /var/www/zoneminder to /var/www/localhost
and now that run fine with 9 sony SNC-CS3P and 3 sony ptz SNC-RZ30P (but ptz function do not work via lan)
only in 320x240 ....
i search for upgrade to 640x480
and i search a method for create the file to cotrol sony ptz cam
where do you go for change rgb?
PS this soft is very very good
